Reyetwinger
This is the back side of the one I removed. It is the same as the one I replaced it with. It is the updated part number (84263144) for the drivers front door. At the bottom right of the photo you see a rectangular clip, there should be another one up towards the middle but it broke off during the removal process. There are little plastic clips that attach to the metal portion and are inserted into holes in the door frame. They broke off and are not pictured here. At the top you see the round clip that accepts a screw from the inside of the door frame. Next to that is the remaining adhesive strip. I believe the older part numbers on these are different...not sure. They may not have all the clips, maybe just adhesive? Hopefully this can help someone out in the future.
