persistent
- Joined
- Nov 10, 2023
- Posts
- 22
- Reaction score
- 18
i'm in the planning stage of doing a dod delete, and i want to replace several other engine components as part of the process, per this yt video.
a generic issue i have is that i don't know the proper way to get a list of oem part numbers. i have the service and repair manual for this 2020 6.2L tahoe, but it's light on part numbers. the diagrams and procedures are clear from the manual, so i don't anticipate any confusion on the processes.
i'm planning on replacing the vacuum pump, belts, oil pressure sensor, high pressure fuel pump, water pump, and spark plugs, in addition to doing the dod delete. i see some comments about replacing the oil pump being risky because if it isn't installed correctly, it can cause oil pressure problems and is hard to access.
i would appreciate any pointers on the dod delete process. i've already done most of the background reading and watched several videos about the process.
thanks for reading
thanks for reading
