Are there issues with removing battery?
jfwhit
I have a 2005 tahoe. I'm needing to remove the battery to get to the washer fluid container. Are there any issues with removing the battery? I'm afraid When I re-install the battery, something may not work properly or I will get an error not allowing me to start the SUV. Maybe something I can do before battery removal or no fears, just remove and re-install.
Also it seems my washer fluid container is leaking where the sensor is connected. Was thinking some silicone will stop the leak. Any thoughts?
Thanks for any help.
MrBalll
West Texas
Clock may reset and if you have an aftermarket alarm it may go off. But no, your good.
Physh1
Just remove & re-install. Reset time & radio stations. You could try to seal with silicone as long as the reservoir doesn't have a split seam or crack in it.
Cameron
J
jfwhit
Thanks for the piece of mind. Battery came out and in with no issues.
