auto to a 5 speed
C
clean454
i really want to do it i found a 95 slivy v8 stick at a pick and pull pretty complete im going this weekend to see if u can swoop the whole truck
and i think it would be SICK to have a lifted 2 door stick!!
EastTXYukon
Longview, TX
I agree, would love to have a manual tranny in my Yuk. I remember driving a 93 silverado with the 5.7 that had a stick. Actually learned to drive a stick in that truck. Let us know what you find. Probably more trouble than its worth, but way cool anyway.
steamroller
The South
I'm working on it right now in my 4 door, swapping in an NV4500. Ive got most of the parts needed except for the clutch, master and slave cylinders and I still need to rebuild the manual t-case. Mounted my clutch pedal and cleaned up all my under dash wiring today
All the holes are premarked in the cab and it has the upper bracket for the clutch pedal, so the swap is pretty straightforward. There's a thread over on FSC by 88GMCtruck in the projects section it's a long read but there's tons of info in there if you take the time to read it. The gear ratios are almost identical to the 4L60E but with the benefit of having a 5.61 or 6.34 low gear and a pretty much bulletproof trans
Ther's already been a couple SUV's complete the swap as well as some trucks. A couple videos that they've posted up that serves as my motivation
http://www.youtube.com/watch?v=M6EGMocUm7Y
http://www.youtube.com/watch?v=lWzxNpDwIRA&feature=related
C
clean454
Probably save a lot of trouble building up the 4L60E, and more fun to drive, too.
i already have a 4l60e WAY BEEFED UP! thats not the problem
---------- Post added at 07:06 PM ---------- Previous post was at 07:03 PM ----------
wow bro thanks for that info!!! im really gunna get the ball rolling on this
steamroller
The South
No problem man, if you need a clutch pedal let me know, I have an extra one from a 92-95 truck
If you can find a complete donor truck that's the way to go, collecting all the little parts and pieces will nickel and dime you to death. Ask me how I know
crmzendrgone
M town Arizona
I had an accident in my pants just listen to this truck.
[yt]lWzxNpDwIRA&feature[/yt]
I think if I had time and money I would attempt this swap!!
96ProCompTahoe
IN
wow, just added that to the ever growing list of to-do's. maybe i need to find a good body and frame and go from there.... hahaha
rxphiler
Charleston, SC
LUV mine it is lifted 2Dr and stock 5 speed!!!! Mine nice only reason I got the hoe because it was 5 speed...too bad my diff just bit the dust!!! good luck with the switch
crmzendrgone
M town Arizona
Can some one take a 5 speed from 86 TA and put it in a truck?????? from what I understand the bolt patterns are all the same from the small blocks.
Aviator_78
