I just received my tunes from Justin and loaded them (87oct,93oct, and trans) to the autocal, plugged it into my tahoe and loaded the 87 and trans. A few hours later I needed gas so figured I'd get 93oct to see its potential. Did/do I need to delete the 87 from the autocal before loading the 93? Right now FULL1 shows 87oct, FULL2 shows 93oct, and FULL3 shows the transmission tune. Is this ok? Do I just select either from there and let it load if I want to ever switch gas octane? Also do you need to reload the transmission tune each time load a different octane setting?
