Automotive Refractometers
L
Larryjb
I agree Chris. For coolant, pH (tested using test strips) is far more important than the mixture unless you live in the far north. I got this hydrometer specifically to check battery acid as a more reliable method to assess the state of charge. I figured the easiest way to check the accuracy of the hydrometer is to check it with a 50% coolant mixture. So far, this device is precise (a huge improvement over the floating ball type), but accuracy may not be any better. On the plus side, if I can figure out how far off a 50% mixture is, I figure the battery acid scale would be just as far off and I can calculate a correction.
Of course, there are other factors that affect all this. Some batteries are designed to have a higher acid concentration. I have not seen any yet that would have a full state of charge with a SG of 1.250. I have some sulfuric acid at work and I will be able to make a solution with a known specific gravity and test it with my refractometer. I think this will be my next step.
SnowDrifter
Washington. The starbucks side not the desert side
yaadablaablaadontwannaquote
My complaint with hydrometers, and this goes for all of them; they're incredibly temperature sensitive. The consumer grade plastic stuff just isn't accurate worth a damn. I've pulled multiple samples from the same 50/50 bottle of coolant and gotten different results depending on if it's sitting in the garage or inside where it's warm. And even with that, slightly different results minutes apart.
They're.... Meh....
Frankly coolant doesn't have to be super exact. You're concerned about your pH for corrosion protection. Some other additives depending on the coolant that provide further corrosion protection (some form a layer on metal parts to protect them), and glycol concentration for balancing thermal conductivity with a resistance to both low and high temperature excursion, and lubrication of moving bits (water pump).
I run 67/33 coolant/water in my rigs for what it's worth.
Also fun little tidbit: Start your truck, dip one end of the multimeter into the coolant, another to ground.
0.25v and below - good
0.3v - look into changing it at next opportunity
0.4v - DANGER WILL ROBINSON
L
Larryjb
They're.... Meh....
Interesting you say that about being temperature sensitivity. I tried a drop of hot water from the tap in the refractometer and it read 0% just like the water at 70°F. Now, what I haven't tried yet is a sample of warmed up 50% coolant. I will try this next because I am curious how much temperature will affect the readings.
L
Larryjb
I have now concluded that the cheap refractometers "aren't accurate worth a damn". However, I think Chris was blaming the inaccuracy on temperature control of the refractometer. I could be wrong. I personally tested mine at different temperatures, even using hot water compared to cold water from the tap. I got almost the same result at 0%. That may change at higher concentrations of coolant, but I saw now issues with temperature. Even when I used a sample of battery acid from my garage which was at 10-15°C, then warmed it up in the house to 20°C, I got the same reading. At least, that was the case for my refractometer.
I went to my lab and made up a solution of 1.341 g/mL sulphuric acid. I did this by measuring out a 10.00 mL aliquot (exact sample) of the solution, and measured it's mass to be 13.41g. This gave me 1.341 g/mL +/- 0.01 g/ml. So, the specific gravity of the solution was definitely between 1.35 and 1.3 g/mL. I forget what specific gravity value the refractometer gave me, but it was higher, somewhere around 1.37 or 1.38 g/mL. By this time I was convinced this cheap refractometer was measuring high at this end of the scale. I calibrated the refractometer so that it would read 1.34 g/mL with my sulphuric acid solution, then retested my 50% coolant. The 50% coolant was almost perfectly on the 50% line after calibration.
This tool, as a cheap tool, is useful IF you calibrate it with a 50% coolant mixture, but it will only be accurate near that range. Given that the 50% coolant line is also near the target specific gravity for most healthy batteries, it is also useful now for battery acid. It would also be useful to determine if one cell is dead, or it is also useful to test to see if the state of charge of a battery is improving while desulphating.
I would love to test truly professional version of a refractometer.
Bottom line is hundreds or thousands of customers who bought this tool are falsely believing they have an accurate tool. Even mine, after calibrating to the 50%, is not accurate through the entire scale.
wjburken
Eastern Iowa
Thanks for sharing.
SnowDrifter
I'll also add, in the professional world, we just use a multimeter and test strips as situations require. Maintenance with a refractometer was never really on our to-do list - time is just too valuable to fuss with it. Especially when you get someone with bunged out coolant and the concern is over corrosion and not necessarily the water/glycol mixture. And putting such a mixture in the thing would **** it up because it's SO bad.
95% of the time we'd just do a sniff test and check with multi meter. Coolant ratios were really only addressed by customer concern or if there was a leak and we had no idea what they've been adding.
L
Larryjb
As a DIY, I agree with Chris. I never used any hydrometer to test automotive coolant. In my class I set up an acid base lab to test two samples of automotive coolant: one new one and one from a car I had neglected. The kids would find the new coolant had a pH around 8 (basic, good condition), and the used coolant was around 4 (acidic, corrosive to metals). After the lab I would tell the kids where the bad sample came from, and that I had a radiator failure 6 months after I changed the coolant, and a catastrophic water pump failure at about the same time that required a tow. I also tell them they can't tell by looking at coolant. I hear so many times people say "it looks okay, no need to change it".
I got the refractometer, not to test coolant, but rather, to test my battery acid. At the very least, I wanted to see how the sulphuric acid concentration would increase as I left the battery on a pulse desulphator. When I first used the refractometer I got a value of about 1.265 to 1.270 so I thought it was in good shape. With the new calibration, that value is more likely around 1.23 g/mL. This was taken on a relatively new Costco battery that I put on a pulse type desulphator after it had been discharged a few times after the vehicle was left sitting for a month. I could not find any significant parasitic discharge, so I suspected that the battery was sulphated after sitting on the Costco shelf. After the discharge, a regular charger was put onto the battery for a day, but two cells remained in a discharged state according to the "ball type" hydrometer. I got myself this refractometer so I could get more precise results. In the end all cells had equal specific gravity (probably 1.23 g/mL).
The 50% coolant mixture can be used to calibrate the tool at the top end of the scale, then used to accurately test battery fluid. (Not many can make a standardized sulphuric acid solution very easily!)
SnowDrifter
For what it's worth, I've found a pretty good method of desulphating a battery is to just.. Beat the shit out of it. Hook up a couple headlights, blower, whatever you want, drain the thing to 10 volts then put the biggest charger you have on it. Do that once or twice and you're in good shape. Hell, I've even noticed if I accidentally run the battery down on my car, once I have it charged up it seems to start stronger than it did before LOL. But... They key is to cram it full of charge as fast as you can. If it sits discharged you get nice little sulfur crystals which works against you.
andrewjles
