Sarge
09 Yukon SLT with Magnaride in front and AutoRide in back. Front has a 2'' spacers and rear has a 1/2''. Links have spacers on rear to adjust vs stock.
Anyways replaced the whole rear compressor unit about 6 weeks ago, went with Arnott complete replacement unit. Installed everything worked fine. Until about a week ago where it would keep turning on and 50% of the time the truck would air up, others it would just run but not air up. Figured the pump was bad.
Last week I replaced the pump again with a new unit. This unit was very quite vs the first so I figured my first one was bad. Installed pump, new relay, checked fuses and unhooked battery. All air hoses/ connectors where fine also. Everything was fine. Started, ran for about 30 secs, everything aired up fine.
Now a few days later its happening again. If i go out and start, it may run for 30 secs +/- and air up fine and hold until i let it sit before it releases air.
Sometimes i can start it and hear the comp kick on but truck does not raise up.
Sometimes if i turn the truck off and let it sit, try again it may air up but could take 60-90 secs.
Whats going on? Lines look good, shocks. No codes, ive discounted battery many times to "reset" system.
Almost like truck is getting confused and needs a hard reset for comp? When the truck does not air up, its not purging out either through the separate line.
Any help would be great!!! Thanks
