Autoride struts
HACK BLOCK
NYC
When I looked up for my 14 denali awd.. I got the monroe 40048 w Z55 Susp
and the ACdelco # was 580-434
Hope this helps.. This would be the correct OE replacement... And retain
the factory Z55 active handling. Which is what I'll do when it's time.
I did the rear shocks last summer with the correct ACdelco air ride shocks
the Monroe 40049 is for trucks with z55 and 22's. I don't know why having 22's would matter
Foggy
KS
Yup.. That was the difference.. I have 20's..
And correct, I have NO idea why that would make any diff at all.. Seems weird
mb1500
22’s are heavier the dampening is probably different
HACK BLOCK
NYC
just to confirm... our only aftermarket options for front z55 suspension replacement is the Monroe 40048/40049???
Foggy
KS
Yes.. Aftermarket.. You can still get the OEM gm ACdelco's... I would think the delcos
are maybe better.. the price is about the same.. Prob just depends on where/how you can get them
St. Louis
how can I find the right acdelco shock?
Can you still read the part # on the stickers?
I know I've seen the OE ones cross referenced by the spring RPO codes, which are usually the last 2 RPO codes on your glovebox sticker and start with a 6 and a 7.
On my RPO sticker, the front spring codes are the 6F1 and 7F1
HACK BLOCK
NYC
i know mine are 6g4 and 7g4 but for example when I try to look up the part number from the ones installed on my truck I come up with nothing. on the acdelco website based on my spring codes I come up with part #19420491 but when I put that part number into Google I come up with 2 items on ebay that I'm not sure about and an out of stock part on RockAuto.
HACK BLOCK
NYC
I also see acdelco part #580-432 would fit but don't know what's the difference between that and #19420491
Mrfirewolf1000
