Aux Fuel Tank 2013 GMC Yukon XL 2500
Caymanboy
Anyone heard of an OEM Aux Fuel tank on a 2013 Yukon XL 2500?
Do they come with one?
avalonandl
Troy, MICH & Naples, FL
The 2500 has TWO tanks, one fill. Iy has a small tank above the rear spare. That tank holds about 6 gallons. You should have about 38 gal total.
Ooooo...
Im getting an idea.
I'd love to add that tank to my truck. It's too tall to fit up above our spare tire as our frames are shorter.
The second tank is just over 11 gallons and has its own fuel pump and float assembly. It's set up to drain at the same rate as the main tank so no separate gauge is required. The PN# for the tank is the same for both generations, the 800s and 900s. HD Rear Fuel Tank - 23306963
Sparksalot
Bastrop County, Texas
If’n the spare goes onto a swing out anyway...
Bill 1960
Testing the Limits
Body lift!
hhonaker
