Axle Wrap .....
F
fktahoe
Charleston S.C.
LOL Springs are gonna run a couple hundred to do too ... quit being a Jew and fix the problem the right way.
im tryin to ***** but im broke lol
---------- Post added at 12:22 AM ---------- Previous post was Yesterday at 11:49 PM ----------
Lift Blocks right now I take it?
Get rid of your lift blocks, and do a shackle flip. A better solution, IMO. This is going to be my first project this year on mine.
http://offroaddesign.com/catalog/shacklekit.htm
hmmmm
---------- Post added at 12:41 AM ---------- Previous post was at 12:22 AM ----------
hmmmm
what the heck causes axle wrap ? i mean ive never had it before then i replaced my transmission and it started doing it after about the first 100 miles with the new tranny!!!
purple 'hoe
Green Bay, Wisconsin
Sunlite Nailed it again. Torque and Soft springs. Axle wrap causes the pinion to either rotate up, or rotate down while driving. Basically, the it will rotate the pinion in the opposite direction as which the tires are turning.
"Simply put, the torque at the tires tries to rotate the axle housing opposite the direction of the tire rotation. Going forward, the pinion rises. Going backward, pinion dives. Since the leaf spring is bolted to the housing, it must try to resist this rotation force. The result being that the spring turns into a Sine wave shape ("S" laying on it's side) and then springs back as all harmonics and vibrations eventually do. Needless to say, the softer the spring and higher the torque, typically means worse axle wrap."
Copied from Pirate4x4
F
fktahoe
Charleston S.C.
word , damn u guys are helpful , but i dont want to buy those shackle flip kits if it still does it , i mean i talked to my buddy he had a silverado 98 on 21 inches of lift and he said his flip kit worked perfect , i donno ! i just dont want to get it if it doesnt work haha
purple 'hoe
21 inches of lift? Holy huge lift. lol Any pictures of said truck?
As long as you keep your pinion angle down, you should be fine. You can get a Zero Rate with the shackle flip, which helps with Pinion angle. Pinion angle always going to be a factor when lifting a vehicle, and always can be one with Short Wheel Base trucks like Tahoe, Blazers, Bronco's and other Fullsize short wheel base trucks. And huge lifted trucks no matter what wheel base will run into that issue. What's your current set up right now?
F
fktahoe
Charleston S.C.
yea they might not be good quality ill get them off his facebook hang on
F
fktahoe
Charleston S.C.
thats how it was after he started doing the work to it !
scoobydont
