bobsburban
- Joined
- Aug 19, 2020
- Posts
- 130
- Reaction score
- 272
So as not to resurrect some years-old thread (of which I've read them all and learned a lot), I'll just ask this one question: exactly where at the bottom of the body would I find the drain/weep hole for the sunroof's rear drain? And is it located where I'll have to remove the running boards to get to it? (Hint: I won't mind a yes answer to that last question - I'd love to lose those things. )
My theory is that gravity being what gravity is, I should have a better chance at dislodging any junk that's stopping up the drain line(s) by coming up from the bottom. And as opposed to the Miata I used to own which required me to clean the drains from the top down, I can get under this vehicle with little effort. I just need to find the holes.
I poked around down there using the attached drawing that someone else was kind enough to post a few years ago but can't find where the drain goes from the bottom point of B pillar where the drawing shows it to be to the bottom of the truck.
And to paraphrase J J Cale, momma won't allow no wet seatbelts in this truck.
Many thanks in advance.
Edit: I guess I should attach the drawing.
