XxBIGxTEXxX
- Joined
- Sep 27, 2010
- Posts
- 249
- Reaction score
- 0
So i did all the work on the rear differential and guess what, the problem was not fixed.. So i get home from driving around and it started smoking from the right side.. Now it sounds like its grinding.. Could it have been that it had to much power that it messed up the gears or something? Would i have to do the differential new and if so, Could i go with a regular stock differential? Or should i do different gears..? Also, I notice the rear metal sheets that hold the frame are flat and not bent like they suppose to be to hold up the body or the suspension... Could that caused the problem or what u think?
