Back End Squeaking
Josh Ellingson
Just bought a 2004 GMC Yukon Denali, test drive was great!
When I was driving home I turned on my gravel road and went over a bump. All of a sudden a loud and painful sound came from the rear end. As soon as i stopped and began to drive again it went away.
It did the exact same thing about and hour later when I started driving again after it had sat for awhile
I have test the suspension going over bumps and curbs. Even drove on the sidewalk and it feels and works great with no sounds
What could be the cause of this sound that happens all of a sudden? My first guess was something to do with the rear suspension. I’m not to familiar with anything on it so I thought i ask
Any thoughts?
could be rear sway bar D bushings they need to be lubed once in a while, easy to do, just have the truck on the ground or on ramps, unbolt the d bushings (10mm), remove the bushings and coat the inside with some lithium grease and put them back on, tighten to about 25lbs I recommend using some blue threadlocker on the bolts as they have a tendency to work there way out otherwise.
if that's not it then check your shocks, brakes, jump on the bumper or something, lol
J
Josh Ellingson
Thank you! I take a look at it today
Stevegmc
