Bad knock out of nowhere! Please help
wjburken
Eastern Iowa
So My 09 Yukon just started knocking last week. I was hoping for lifters or something lesser but the more I'm reading, the less confidence I'm having. The knock is consistent with rpms and acceleration. Check Engine and Stabilitrak flash at 2500 rpms, then rough idles for about a minute or two. I've changed the oil and added Marvel Mystery. It's quieted the noise slightly, but I'm still concerned.
Does your Yukon have the 5.3 or 6.2?
How many miles on your vehicle?
Have you been able to read the DTC codes with a scanner?
What did your oil look like when you changed it?
If you can post a video so we can hear the knocking, that might help folks here help you.
5.3l v8
130k
I don't remember the exact readings but there were several.
The oil was super dark, didn't notice any sludge or metal.
I also noticed oil leaking near #7, but when we pulled the plug it was dry.
wjburken
Eastern Iowa
5.3l v8
130k
I would not rule out a lifter, or lifters, being collapsed. I believe your vehicle has AFM. Getting the codes would be helpful.
When you say oil is leaking near #7, what do you mean?
I'll post the codes tomorrow when I can run them again.
After I changed the oil and whipped away the residue, I started her up and I noticed leakage just below where #7 is but could not pin point exactly where it was coming from.
wjburken
Eastern Iowa
Sounds good.
I noticed that it looks like you have a conversation on this topic going on two different threads. Might be good to keep both threads updated with your codes when you get them.
Sounds good.
I will... going to try and upload the video now.
donjetman
Sounds like its in the valve train to me too. Lifter, valve spring, rocker arm, push rod/
Not good
Don't drive it
Pull one valve cover at a time and look for the problem
Not good
Don't drive it
Unfortunately, we don't have a choice but to drive it. We're limping it when we do. Gratefully we don't have to go far.
Kingjackpot23
