bad O2 sensor
jomulk56
Resident Lurker
IN
If you have a bad O2 sensor you usually have worse than usual fuel mileage because the truck is running rich. So you'll smell fuel, and your check engine light will be on...usually.
josueh95
bad milage, bad idle, lagging when you hit the gas, missfiring,
just spent 2 month with all these symptoms until i found out it was the connection of my 02 sensor..those 02 sensors are a crucial part of these trucks performance
SLCHOE
ASE Master Certified + (L1)
Midvale, Utah
Since it will be running rich from being in open-loop, there will be unburned fuel (HC) entering the catalytic converter. This will detonate inside of the cat causing premature failure. A couple of O2 sensors is way cheaper than a couple of cats. Get it fixed asap.
BirchyBoy
I've got an OBS and my light came on a couple weeks ago. I did notice a drop in MPG but thought it was because I had been heavy on the gas. I replaced the O2 sensor this weekend and it does seem to be running a bit smoother. Could all be in my head though.
jomulk56
Resident Lurker
IN
That's no doubt. I had to replace the y-pipe/cats and all four O2 sensors right after I got my hoe.
98[Ta]Hoe
Columbia,SC
how many O2 censors does a 98 tahoe have? my engine light is on saying something about my O2 censors.. i replaced 2 of them myself and light still came back on
Tahoebigdog03
Should be four 2 up and 2 down if I'm not mistaken.
Sent from my SM-N900T using Tapatalk
Rubeng0315
