bad O2 sensor
98[Ta]Hoe
Columbia,SC
Should be four 2 up and 2 down if I'm not mistaken.
Sent from my SM-N900T using Tapatalk
are they all the same?
and thanks for your response
---------- Post added at 06:25 AM ---------- Previous post was at 06:24 AM ----------
any good brands anyone recomends?
and thanks
Tahoebigdog03
They should be the same also I would try to get close to OE as possible.
BirchyBoy
Yes. Mine was the bank 2 downstream sensor and had a P0430 code. 50/50 chance it was the sensor or the cat. I took the cheaper option first and tried it.
Tahoebigdog03
Same code dude the cheapest route is what I tried also and it work. Lol
jomulk56
Resident Lurker
IN
and thanks
I used Bosch when I did mine and there's 4 different part numbers to choose from based on your model. The front and rear should have a different number tho.
valleytahoe956
valleytahoe956
on mars
Ok, I went to auto zone to find out which ones I needed to replace & they told me it was bank 1 & bank 2.. Would those be the ones before the cat ??
missta
Nork, NJ
I have check engine light as well...replaced all sensors...light went off. .then returned
BirchyBoy
Just to come back to this, my light came back on after a few hundred miles. Replaced the cat and no light after 7k miles.
missta
Nork, NJ
Did you order your cats online or had it done at a local shop BirchyBoy? How much did it run you?
Ne44035
