BAGS going in!!!
J-Will
#Merica
SW MO
50 should lift your rear end. slow but itll get it up there. idk why youd have to upgrade your compressor to get the front up if its not enough. just the pressure switch. unless you plan on runnin the shit out of the compressor.
SSmurdered
SSmurdered
i know u see me
Pittsburgh, PA
my compressor is max at 150psi, some peeps said they needed more than that. but fast bags arent my vision.
SSmurdered
SSmurdered
i know u see me
Pittsburgh, PA
got my package on wednesday from airbagit.com, and a trip to home depot today makes my rear kit complete if my calculations are correct. tomorrow is the day!! got my buddys dads shop for the day to start hackin. excited and nervous hope all goes well. ill post a full write up with pics when its all done.
SSmurdered
SSmurdered
i know u see me
Pittsburgh, PA
ok so i got most of the install done today. ofcourse my shop time was cut short and couldnt finish it completely(i need my own garage BAD). still gotta weld the bag brackets together and pop them in, the lines are all there and ready togo. heres a few pics to hold yall over.
shock and sway disconnected with the spring out ready to cut out the bump stop
bump stop out and cleaned up
tank valves compressor mounted in spare tire location
bag next to the djm -3" spring
dual needle gauge mocked up in the old onstar spot
trying to get a spot in the shop on wednesday to finish it up.
SSmurdered
SSmurdered
i know u see me
Pittsburgh, PA
ok mfers!!!!! got these pics of the rear setup done!!!! it was my first air ride install, so i came into this kinda blind except from what i gathered online. im really happy how it turned out. goes up quicker than i thought it would (doesnt hop but takes like a second to go from aired out to like 100psi). hitting the switch just gives me an instant *****. rides way better than my djm -3" coil did. it seriously took 20 hours between today and last sunday to get it done(first timer remember). ok heres the pics.
switchs and gauge
axle with factory coil perch
some scrap steel for the upper cups
little torch for cutting to length(1 3/4 tall)
some heat and a vice to round the cup to the plate
good people right here
trimmed the ring off the bottom perch
lower plate. bolt welded to plate, plate welded to axle
top plate complete. i used the top plate i got off airbagit.com, the scrap steel 1.75 tall, stud welded to the cup for bolting it into the factory upper perch. i wanted to make the bags removable so if i need to swap them or whatever, so to put the bag in i twist the bag down onto the bottom plate then set the stud from the upper mount into the hole i drilled in the factory perch then bolt it tight. simple and genius i might add! jk
all in place and bolted up
heres the finale.... heres aired up about 100psi
heres aided out almost all the way about 10psi. those are 26x10s with 305/30/26s just clearing the quarter panel!!! might go a smidge lower at 0psi.
heres the gauge again with pressure to it, tank psi at 135 and rear bag pressure at ride hieght 45psi
sorry for the blurry camera phone pics. cant wait to start the front, might wait til winter when i spray my wheels pewter to match the hoe.
---------- Post added at 12:46 AM ---------- Previous post was at 12:35 AM ----------
reminder of the hoe with the old lowering springs ( thats about what it looks like at ride hieght with the bags)
im still using my sway bar and panhard w/ the free travel mode and the hardware kit. used 2600 series bags NOT 2500, just about 1/4 inch clearance to the frame
matt14
san leandro,ca
****, tuckin 26's! So on a scale of 1-10, how difficult was it to install and how much expierance do you have wrenchin?
joakleyTYF
