Ball joint nut size
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Need tool size for the for the upper BJ Big nut on 96 4x4's It not sae so I'am thinking maybe 26mm? Anyone know for sure so I get the right tool while driveshaft is installed. I also think I have asked this before but can someone confirm that the upper and lower C-arm bushings can be replaced my self or will I need some heavy equipment. I have my new Energy Suspension bushings to go in while I do the bj's
retorq
Kingman AZ
Can;'t say for sure about the ball joints but I did have to buy a socket as I didn't have one that fit. I'm pretty sure the guy at AutoZone was able to tell me what size it was. I was able to get my old bushings out with heat, drill and BFH.
TigerEyz3
Slow and Steady
TN
Don't know all the quirks associated with the 4x4 arms, but when I replaced the bushings on my 2wd (stamped arms vs. forged), I was able to do it with basic tools, some heat, and a hammer (to get the rubber bushings out of the arms).
lordgorlok
I just did my upper bjs on my 96 4x4. I got a 1 inch open end wrench to work, but it was a tight fit. However, it just needed to be broken loose, so a crescent wrench might even work. 1 inch is 25.4 mm I believe, so a 26mm should work.
Roux
