battery not charging light
Jon Chimpo
Hey all,
we were driving home last night 8hr drive. I noticed the headlights dimming. At first I thought it was my eyes messing with me after driving 7 hours. After about 20 minutes of the lights flickering from bright to do, the battery light intermittently came on with message "battery not charging". The voltage gauge looked around 12, but then went back up to 14.
What do you guys think, alternator? Loose connection, battery?
J
Jon Chimpo
I checked the connections after work. Everything is tight. Went to autozone for a test, yup, alternator going out.
So they don't sell any new Delco 145amp alternators, only reman. So i want Delco, but a new Duralast has a lifetime warranty, and is the same cost as Delco reman with 2 year warranty. What you guys think?
S33k3r
Dallas, Texas
Do you have AC Delco options for an alternator LARGER than 145 amps? That might be the way to go.
J
Jon Chimpo
There might be, but i just put on new belts for the 145 size. Does a larger one require a larger serp belt?
JollyRoger01
Christ Reigns
NC
Some performance alt use an overdrive pulley, but when I replaced mine I was still able to use the longer of the 2 belt options.
J
Jon Chimpo
I am using the larger of the 2 sizes because of the 145 vs the 105. Ill check, but im guessing they won't have any new Delco alts. Nomatter what size.
JollyRoger01
Christ Reigns
NC
If you go to Advance ask them to check with World Pac for the Delco. You should be fine since you are already using the longer belt.
Yuk04
