95escahoe
- Joined
- Aug 2, 2010
- Posts
- 5,157
- Reaction score
- 4,463
Actually that was for blueflame but now that you mentioned more on yours then yes work your possible ignition switch wiring first.
ALso check your ecm-b fuse under hood for a dirty or bad connection. It provide line voltage to the fuel pump relay on the same fuse block. It would not hurt to look at its terminal as well.
In terms of the wiring do u mean taking the ignition switch out and checking that wiring? and for the fuse, I know where the fuse box is, never really looked in it before but is the fuse im looking for called ecm-b? cause I dont have the owners manual so I have no clue as to the layout, and the fuel pump one is next to that?
Back to the fuel pump, I had a Mustang and it had a bad fuel pump it wouldnt start on hills and sometimes you'd turn it off and it wouldn't start back up, if my fuel pump was bad wouldnt there be other symptoms cause i've had this truck for like 4 months and it hasn't gotten any worse its still the same, cause the only problem I might have is the check valve being bad but maybe its a wiring or fuse problem....thanks for the help
