Battery?!
Smasal
Smasal
Southwest, Mo
mmeachem
Never heard of either but DieHard and Bosch are the ones I used
Gzes
the drifting 2dr
Wichita tx
Everstart is walmart. Never heard of the other one.... The walmart one does the job
Smasal
Smasal
Southwest, Mo
Next pay check I'm gonna invest in a nice one. This wal Mart one seems to make the voltage meeter bounce. Very odd. Alternator maybe needs a look at.
Denali0229
FL
Are you using the batt only as a starter batt or for a bunch of electronics and other stuff that will drain your batt?
Sent from my PC36100 using Tapatalk 2
Gzes
the drifting 2dr
Wichita tx
Yea u probably need a new alternator. When mine was out it wluld just run off the battery and it would not really work too good.... It was on a pos ford btw
Smasal
Smasal
Southwest, Mo
Well that doesn't bother me too much. I know I can pull the alternator and have it tested to be good or bad. Then go from there.
Wake
Stafford, VA
The Walmart Everstart actually gets really good reviews. I've used them in a few vehicles over the last few years with no problems and easy replacement for the couple that have gone bad.
I used to use only Optima red tops although the last few I've had weren't very good. The first one was still kicking 7 years after I purchased it. The next couple only gave me a little more than the 3 year warranty before needing to be replaced.
The next batteries I'll buy will likely either be the Walmart Everstart or an Interstate brand.
Svk_22
