BBP tune issues with e85 ?
NYBRD
Engine came FHO from factory so its not e85 ready my fault I'm an idiot
Has anyone had any issues runing a BBP tune adjusting to e85? 2nd time this week I'm getting a P0171 lean code I am trying to run e85 now I was under the impression while runing the Black Bear performance tune it should adjust to e85 normally?
My freeze frame data is showing 34% for both LTFT any suggestions ?
P.s. I tested the e85 it's good to go tested at e83
the 18th letter
Northern New Jersey
I think it depends on the tune. Recently did my tune and I have an 87/89 tune and a 92 high octane tune, which I assume is for running E85, since I have the 5.3 flex fuel. I did send BB a message asking for clarification.
NYBRD
NYBRD
I have been running on the BBP high octane tune and E85 for better than six months with no issues. You sure you don’t have a vacuum leak?
No leak last time I checked also is the e85R percentage value supposed to change at all ? Mine stays constant @ 9.8%?
the 18th letter
Northern New Jersey
5.3 L83 flex fuel engine
Has been on 93 octane for years until now that I've started modding the engine and have been switching to E85
Engine has 80k miles
I’ll let you know what BB tells me when they respond. I use E85 every so often for the cleaning benefits as it’s about the same cost as 87 but burns up faster. I’ve never ran super unleaded in mine.
If that's what the scanner is telling you the alcohol % in the tank is, then the PCM isn't calculating that properly. It'll run lean since it's not delivering enough fuel to the engine.
NYBRD
NYBRD
DISREGARD , IM AN IDIOT AND WILL KEEP THIS POST TO REMIND MYSELF
Scanned QR code on driver door jamb and found out it's FHO which is pump gas only
FHS is for e85. Sooo is it easy to make this engine e85 ready ?
AChevyKing
