BCM Programming... who and **?
Fless
Super Moderator
Elev 5,280
I can confirm that this USB serial converter (dongle) works in WinXP:
https://manhattanproducts.us/products/manhattan-en-usb-to-serial-converter-205153
I got mine at my local Microcenter store for $22.
Curious, though, there are several drivers available on Manhattan's web site. When I had Virtual XP running under Win10 the driver that came on the included CD worked to connect to the Tech 2. However, that one didn't work on a laptop running XP natively; I had to use one of the ones on the Manhattan support site.
energizedtech
energizedtech
Ottawa
@Fless It's an option in the silly Tech2. I could probably get an adapter and do it all on Windows/Linux but well.... that's just me and i try to stick to a stock solution vs. a Sean created one ;)
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
Actually, I copied the software from my pcmcia card to a .bin file and emailed it to @George B who wrote it to his pcmcia card to update his software version.
Yeah, I accidentally erased my card so we tried writing it and it worked.
To sum up what we did here:
I accidentally saved my PCMCIA card back to an older version.
Using a windows 10 laptop running a virtual machine loaded with XP and connected to the Tech2 with a SERIAL to USB adapter I was able to follow these instructions and load a .bin file that a member was able to save and send to me via file sharing. I am not sure if the writing software would work on windows 10 or not. I used the virtual machine because it was all set up to communicate with my tool through the adapter already.
energizedtech
energizedtech
Ottawa
Any chance you may still have that BIN file booting about? I would quite grateful. I mean the Tech2 *is* working fine now but on an older version of the software that has no clue what the year 2021 is ;)
Oh ... good grief.... same site... I can see the needed bins :) Thanks for the nudge!
George B
¯\_(ツ)_/¯
If you need it I still have it.
energizedtech
energizedtech
Ottawa
@George B Thanks for the hand up. I found the bins on the site and have brought my tool back up to the most current NAO bin :)
Also just ordered a battery for my Lenovo T510. It's running Windows 7 with no Virtualization needed and all good.
Now to read up and see how to use this beast !
energizedtech
energizedtech
Ottawa
Now onto the final phase which is getting the Steering Wheel wired into the Radio. I picked an Axxess adapter but it looks like it doesn't like my AVH2400NEX (it wants the Idatalink connector) so that arrived today.
The only "Scary part" is running a wire down to Pin 31 to pull the Steering Wheel control pulse and "patching in" to the wire. Once that is done it will be operational. As an added bonus I found out my AVH2400NEXT has a hidden DVD slot. So I ordered in the Parking Brake bypass from Metra for $30 to get it all running the way I want it to.
Now I have to wait until dinner break to plug it all together :)
Waiting_to_Dye
