Belltech 2-3/4 drop
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
The airlift helper bags will fit righ tin.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
in rear if your at 3 inch level cut the belltech stops a little. but if your going for a 4 inch full drop cutting the bracket is mandatory for a good ride
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
if your shocks are shot i would change them out. If its close to the bumpstops in rear cut the bumpstops and or bracket
2005SnowKon
Fort Collins, CO
Shocks are brand new. I already shaved the rear stops which actually helped
ludvball
ludvball
I am finally getting ready to upgrade my wheels and tires. I am going to go with 20" rims. There are three wheels that I like. Each have different specs, listed below. I am also not sure if I should go with the 305/50R20 or the 285/50R20. It is mixed driving......local, highway and some towing. I want to make sure they will fit with little to no rubbing.
20x9.5 20mm offset 6.10" back spacing (305/50R20 or 285/50R20)
20x9 30mm offset 6.18" back spacing (305/50R20 or 285/50R20)
20x8.5 10mm offset 5.11" back spacing (305/50R20 or 285/50R20)
So, will all three of the wheel set ups fit ok? Can I go with any of the tire to wheel combos? Any help would be greatly appreciated.
Black0460hhh
