Belltech 2/4 drop
crew chief
Puyallup WA
I just installed the Belltech 2/4 drop yesterday that I purchased from Tony.
The installation was fairly easy and took about 3 hours. I cut the bumpstops as Tony indicated and set the air ride links at 3". There is a little rub on the inner fender with the wheels turned hard.
Here is the before and after measurments:
LF 35 3/8" 33 1/2"
RF 35 3/8" 34"
LR 37 5/8" 35 1/2"
RR 38" 35 1/4"
NathanJax
Vacation Nathan
Administrator
Jax, Fl
Good looking Denali!
I'm guessing 22"s?
C
crew chief
Puyallup WA
The RR started out higher than the left with the factory springs installed. These measurements were done right after the drop so I am hoping the rear springs will settle a little bit. The compressor seems to kick on more than before so I am going to adjust the links to 2.75" and see what happens. The ride is great for a lowered vehicle.
KMeloney
That sounds high with no spacer. You definitely need to shorten the links. I know Tony and I have gone back and forth on this, but I think that the links need to be shorter.
C
crew chief
Puyallup WA
After the drop and front end alingment my wife was driving down the freeway and experienced a "death wobble" in the front end. It has only happened once so far. Have any of you had this happen or have any idea what caused this?
gordo214ace
