belltech 736sp
bigm00ch
Orange County, Ca
So its time to sit a little lower. I was informed the Belltech 736sp is what I need for my 2008 Tahoe 2wd w/out autoride.
Front 3"/ Rear 4" w spindles and sp shocks.
Is this the correct set up or am I missing anything I should know about?
Thanks! I can't wait...
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
i sell and install these kits and a few things you should know.
1) wasting your money on the springs you just need the drop struts and spindles
2) the 4955 kit they have there is kinda not the best bang for buck. the 4957 kit i sell comes with new cam locks and only 15 bucks more deff worth it
3) rear springs is the 23323 and i wrote up about this they dont ride as well as the 5305 coils at all
4) your not gettign shock extenders on the back
5) 4 inches requires free travel mod and djm endlinks and my swaybar which is 110
that kit your spending over 1050 on and honeslty not worth it so heres what i would do on a truck im setting up and installing on
1) front 2511 new belltech design spindles
2) front 4957 camber kit
3) front belltech sp drop struts
4) rear 5305 coils with shock extenders (true 4 inch drop)
5) rear belltech sp shocks
6) rear djm endlinks for swaybar
7) rear my new bumstops for free travel mod
$1020 shipped and you will have much better results and will ride a lot better than the kit your looking at but THERE IS BETTER.
if you want a true proven set up on here for the best ride and a spring that i designed that by far rides the best here yougo
http://www.tbssowners.com/store/index.php?act=viewProd&productId=192
bigm00ch
bigm00ch
Orange County, Ca
Thanks for the input guys!
Is this something I could do myself or have it professionally installed? I've lowered vehicles before but never with spindles on a Tahoe.
Tony - ill get back to you soon. My belltech hookup is family. If the order was placed, could I order the missing parts only?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
return the front springs/rear springs you dont need it
in rear do my 5 inch kit since you ahve the shocks you will need
my springs 225
1 inch spacers 40
rear djm hardware kit 165
my rear bumpstops 25
then if you want to tow I designed the springs to use the 60742 airlift helper bags and you can tow a car and really load it up. due to not having dead springs the bag can wedge itself between each coil which mean much better towing/load capacity.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
No prob. If your gonna do it once might as well do it right. I set these things up a lot trust me.
bigm00ch
bigm00ch
Orange County, Ca
Ordered and on its way:
Tony's 5305 springs
DJM rear hardware kit
New bumpstops
60742 helper bags- Amazon for $78
Belltech 736sp kit
Thanks again Tony!
I'll post pics in the next few weeks.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
its not even close to the 5305 springs they are my own custom spring. You will use the 1 inch spacer from your rear 736sp kit
bigm00ch
bigm00ch
Orange County, Ca
Thanks Tony, my mistake. Not the 5305, we're going with your 6" springs.
Also ordered the DJM front/ rear swaybars from Tony this morning.
I cant wait...
Skylander
