Belltech spindles not 2"???
gat0r
DFW
there have been other users reporting full 2" not seen in past.
K
KennyK
Did you measure immediately after lowering or did you drive for a bit to settle everything? Yes, the proper/accurate way is to measure from the fender to the hub.
measured after moving around the yard some then again once i drove it home.
olyelr
Elk Rapids, MI
Measuring from the ground up, on the same vehicle with the same tires/wheels kept at the same air pressure, should not have much of a variance in overall height at all. However, it is indeed more accurate to measure to the center if the hub (especially when comparing vehicles).
Sounds kind of like a copout from Belltech. Although they are indeed correct, your measurements should not have been swayed much as long as you did not change wheels and tires or air pressure.
K
KennyK
That's what I was thinking. What's crazy is I usually do measure from center is the hub to fender but for some reason I decided not to because I mostly see people's measurements on this forum from the ground up and I wanted to compare them
K
KennyK
How it's sitting right now. Got some struts on the way to get the front down a lil more
Danyi2170
San Diego
It's 4.5 but it's actually sitting a lil lower
Looks really good. What size tires are on those rims? Any rubbing issues? I’m doing a front spindle drop soon. Hope I get the 2” drop. It’s a McGaughys spindle with upper control arms.
K
KennyK
305/35. It was rubbing a little at the rear bottom part of the liner. I pulled the liner back and gently persuaded the fender back and then added another torx screw to pull the liner back
K
KennyK
do people use the rear lower control arm relocation bracket like the ones from djm on these newer suvs?
bruh2125
