Best coil pack replacement?
M3kanic
Are you tuned? That is how I found out about intake leaking. It is not that hard to pull off. Even a complete novice can do it under 2hours, and that's being generous. Z71tahoe-suburban has good write ups you can fallow.
Sent from my SM-G900V using Tapatalk
JubjubW
JubjubW
Wausau, WI
Tuned? Nah truck is completely stock minus a drop in kn filter
Sent from my SM-G900R6 using Tapatalk
JubjubW
JubjubW
Wausau, WI
Well they did a compression test, checked out. Fuel delivery checked out. Electrical checked out. Before they dug more and racked up my bill they narrowed it down to mechanical and missing on 6 and 8. So could be a bad valve spring or a cracked head. Arrgh.
M3kanic
Maybe trunion bearing. Ls are known for not being that great.
JubjubW
JubjubW
Wausau, WI
Wait what? How would that affect my misfire
M3kanic
They are the bearings that locate the rockers. If the end caps come off (the common problem) the needle bearings may fallout resulting in a valve not fully opening.
JubjubW
JubjubW
Wausau, WI
Ohhh I had something else in mind. I'll check all that when I rip it apart
M3kanic
You should be able to take off a valve cover and see. Iirc comp cams makes some of the best trunion replacements for not that bad of a price.
JubjubW
JubjubW
Wausau, WI
Thanks for the info. Hoping to get under the valve covers this weekend
JubjubW
JubjubW
Wausau, WI
FINALLY got under the valve cover and all my springs are fine. It all looks fine too
I can however move some of my rockers by hand
Smityinms
