Best lift Springs???
cmcarr85
I just bought my first Tahoe and can tell you its amazing.
It is lifted from what I am told with a 6 inch fabtech lift and 3 inch body lift.
the back is lifted with blocks and helper springs. I want to get rid of this setup and throw some springs in their instead. Any advice on some good lift springs?
i would assume I need a 6 inch spring right?
Also is their any way to tell if the tbars have been cranked???
I am running a 37x12.50x15 and would like just a better ride already have pretty good clearance.
Thanks
96ProCompTahoe
IN
Procomp and BDS make lift springs, not a clue as to price other than i got quote on some BDS a long while back for $300 and some if i remember correctly.
C
cmcarr85
300 for both? damn thats pretty good plus bds has a lifetime warranty...
thanks
96ProCompTahoe
IN
it was through a buddy at extreme performance in town, and awhile back. so it could be a little different.
C
cmcarr85
ok... i have what seems like some axle wrap with the set up now but will the springs fix this???
i have a block on top of stock springs with an add a leaf on it now. everything is tight but it still makes the noise?
96ProCompTahoe
IN
you mean you have a block under the leaf springs between them and the axle?
mine has the add a leaf and block b/s, and the only noise it makes is the squeak from the pads between the leafs being gone.
C
cmcarr85
yea its axle-block-leafspring.
it makes it feel like the axle is gonna moves when i hit the gas at first. like its moving.
i dont think it is a squeaking noise. ill get some pictures so you can see it.
ggilpin
