Best lowering kit?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
That kit will work. Whenever more then 3 inch drop is needed in rear I cut bracket off frame
smithl3
With the use of the Belltech spindles in the front, will the stock spare still fit up front? I ask because I lowered my 2003 Silverado SS with a McGaughys kit and could not use my spare in the front.
992dr
Eastern N.C.
if you use drop struts with 2 inch drop springs keep it at 0 drop on the drop struts then the new belltech spindles and camber kit.
2 inch spring/2 inch spindle will need camber kit
Its been a while hah.
Through some luck and tough bartering I have acquired belltech struts, rear shock extenders and djm rk2007 kit.
I would like to use your rear 6" coils.
Is the only thing I need the camber kit?
Should I get the camber bushings?
My goal is a 4/6 drop.
Thanks
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
do you have spindles right now and if so belltech has a new part number for 3 inches or more which i highly recommened.
you will need the front camber kit and rear shorter shocks from belltech those 2 are 185 shipped
my springs are 225
also do you have the new bumpstops for the free travel mod in rear that is needed?
do you have the panhard bar also for the rear?
992dr
Eastern N.C.
Aww crap, I forgot about the rear shocks and ph bar.
No for the bump stops to.
I don't have spindles, I have 2" drop coils.
Why are those spindles so highly recommended?
Is a 4/6 drop doable with the coils and struts up front?
Yeah, this isn't going so good after all, hah.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
you cannot do springs and drop struts it will kill the shock and no travel. ride is horrible and due to the drop struts having a lower spring perch the drop springs are shorter so it moves arond.
i have a sale on the rear bar today is last day 105 shiped
bumpstops for free trael mod 25 shipped
shocks and camber kit 185
front new design belltech spindles 275 shipped
992dr
Eastern N.C.
Damn, so the struts are going to be useless?
2" coils with spindles would've been the way to go huh?
Do you accept paypal?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
yes all thru paypal.
struts you can use with oem springs and no spacers will give 2.5 inch drop.
992dr
Eastern N.C.
Well this is great.
Can I grab the bar off of you?
I'll have to do a little finagling this week for the rest.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Well this is great.
pm me your email address. i will send a paypal bill for 105
Jscan
