big brakes HELP
InTruckDesign
SW CT,
It is a brake bleed and the Tech 2 will need to be hooked up...should take roughly a hour to complete.
Do a normal bleed, then with the bleeders shut, command the ABS bleed with the Tech II, then, while commanded, repeat the four corner bleed
tygbenn
