big project pls every one come in !!!
Qatar83
qatar
Hi im ahmad from qatar ,,
I need to start my big project with my tahoe 1993 so my $$$ is open
First suspension ,, im think for 4 inch or 6 inch
so what lift size and body lift size its well work nice for
street and offrode everyday driveing
and what about rear drive shaft??
And suggest about tire and wheel size ??
2- the transmission th400 or nv4500
3- the engine 502ram jet or lsx454 or ls 6.2 or 6.0 or crub old 454 ??
4- what I will do with front and rear raito size suggest me ??
What color will every on suggest my car red now ??
Pls I need info and any web to start order and complete my project
tnx for alll
Ahmad
yates ™
Resident Apple hater
Iowa
If you're doing a lift please just do all suspension and skip the body lift.
jdpber
GOLD MEMBER
The America
what is the budget?
the desired tire size will determine the lift size along with budget.. as yates said.. all suspension or don't bother..
Ceejkay
Ft. Lauderdale, FL
I think you need to sit down and really think about parts availability, cost vs gain. are you doing the work or is someone else. labor isnt cheap and a broke truck that is out of the norm is just as expensive.
IMO: if your going thru the hassle of doing a bigger motor, trans, and maybe tcase, do a sas. while your at it get you a 14 bolt rear. depending how parts are over there, if you do all your own work you should be able to get a sas for in the neighborhood of 2500$ usd. Either of the motors you listed will take a bit of work, again IMO go diesel. If it were me i would take the advice of retorq
Wannabez71
