Pimpin Frog
Heyyoooo,
Can't tell you guys enough how much I've lurked on this site for answers to my builds. I'm new here (I feel like everyone says that) as if my post count doesn't tell you that. Anyways...I have a little bit of a problem with the shocks I installed on my 07 LTZ Tahoe.
She came with autoride suspension on her and I disconnected the compressor, kept ALL coil springs, strut mounts and etc. I removed the autoride shocks on all 4 corners and replaced them with Bilstein 5100's---front shocks are part number BSN-24-186940, rears are part number BSN-24-187237. The front were installed and put back together correctly. The first thing I checked was to make sure that I didn't put the lower spring seat/cup on upside down, and I did not. The front is now level with the rear at that lowest spring clip setting since the fronts are ride height adjustable. Any thoughts? Bilstein even says thats supposed to keep the factory raked stance. Do I need to change the coils? Are they different on the autoride than a standard gas shock?
Any help would be appreciated. Thanks
--Ribbit--
---------- Post added at 09:50 AM ---------- Previous post was at 09:04 AM ----------
Would it be a constant rate coil spring vs a variable rate spring upfront (What came with the autoride suspension in 07)? Is that different than what a regular gas shock/strut assembly would have. I'm tempted to pick up the cheapest OEM front struts and take the coil spring, strut mount and hardware and place it onto my vehicle.
--Ribbit--
