Belltechs are way softer.
Do you have the original shock at all still? As i said before ive seen variances with aftermarket companies where the snap ring is at. If the snap ring is much higher on your shocks now that explains the lift and I can mill it down for you to lower it.
im wondering if you got the lifting ones now.
Never thought of that
Thanks
Will the lowering struts by bell tech be a comparable ride to the bilstein
What do you guys use for a lowering strut
honestly can you be without the truck for a few days???
I can machine them down after work and send it back out to you the next day. I would just need to know how much lower you want the front. You have the struts already so might as well go with them.
