Not really looking for advice, more just venting. I recently purchased a 2001 Suburban 4wd. The truck is a bit of a project but seems to run ok. I've been fixing leaks here and there but now it seems like with each leak I fix, another leak develops. So far I've resealed the lower oil pan, rear main seal and housing, replace the power steering pump and high pressure hose. Now it looks like I have a new power steering leak, the pinion seal on the front diff is leaking and possibly the pass side front axle seal is leaking. These are new leaks and of course leaks are frustrating to chase down, ugh! I've also replaced the transmission and I've been going through the wiring in the truck chasing little gremlins.
Btw, if anyone has the OEM CD player for a 00-01 Tahoe/Suburban/Yukon/YukonXL, I'm looking for one so I can get this aftermarket stuff out of the truck.
Thanks for listening/reading.
