So this the problem I have the sway bar end link hole and the control arm end link hole do not match up, the closer they are together the farther apart they get.
Options?
1. Drill a new hole in the control arm (even if I have to have a piece welded on for more room)
2. Grind the sway bar a bit and drill a new hole in it
3. Use the factory sway bar off of the Yukon which is slightly bigger than the oem Silverado one but may not line up any better.
4. Weld some metal to the frame and relocate the sway bar d bushing mount holes back a little.
All I can think of at the moment
even though it doesn't really look like it but once the bushings are off of the control arm there is a little room to make a new hole that is better aligned, that may be the easiest.
I am assuming @Rocket Man must have ran into a similar problem?
Options?
