Black Bowtie's: are these the one to get?
Zirotti
I'd love to know as well! Just picked up my '10 LT and need to do some work on it bad ;)
zach2011
Platinum Member
There are 2 10mm bolts holding the bowtie to the grille, and then it has a square patch of double-sided tape. So after you remove the bolts, you pull off carefully but with force.
As for which bowties to use, I just removed my gold one and painted it OEM GM black paint and added a clear coat.
jee123
i have those...the front is just taped on dont think there were any bolts..use a hair dryer to heat it up and use a lil screwdriver to lift the corner to pull it off....the back is just stuck on, use a hairdryer heat it up, remove the sticky..i used rubbing alcohol for that..they have some with different colored outlines out there
emann_01
or just get a quality rattle can of black paint, tape everything off, scuff it up, and paint?
10 bucks opposed to 70 bucks?
I talk to a buddy of mine who owns a body/paint shop and he suggested this... thoughts?
Zirotti
I would still recommend taking it off and painting it. It should be relatively easy it sounds like, just may have to find some 3M double-sided tape after you paint it.
Choppa Jon
PA
Hey I just did these last weekend. If you want it done right you have to remove both emblems, prep them and paint with a basecoat clearcoat. These will last forever. I woudl stay away from the spray cans because the finish will come off in time
AV2TA
Houston-Sugar Land, TX
Best of all, you don't have to wait for shipping. If you mess up, just sand it down and try again. I did this on day one.
Burgy
