Black Mesh Grill
GalaxyBlackEsky
BlackedoutLT3
MD
Yeah with that one that you have linked on your first post does not require cutting. But to be honest it doesnt look right it buldges out because it goes over that cross bar so you don't cut. I will try to find Hammers thread when he installed that version.
babamerino
babamerino
Honolulu, Hawaii
So your saying I would have to cut in order to install the "better" one with no bulge?
---------- Post added at 09:49 AM ---------- Previous post was at 08:48 AM ----------
Found some other ones on ebay... any thoughts?
http://www.ebay.com/itm/310353500491?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
http://www.ebay.com/itm/170684087141?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
http://www.ebay.com/itm/120808481305?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
Thanks
Blazed
Accepting Donations
Thanks
I like the first one best. The middles one the mesh is too big
Blazed
Accepting Donations
That means its incomplete and dont get it lol
GalaxyBlackEsky
BlackedoutLT3
MD
Thanks
Yup. need to cut to make it sit flush and looks so much better. Second one is same exact one I have. To be honest it was very easy to install. only thing you have to do is remove old grills and just dremel straight down the cross bar and then install the other and it mounts up top with same screws as OEM and then double sided tap around bottom and edges.
babamerino
babamerino
Honolulu, Hawaii
Will I be able to go back to stock?
haileyds
