Black Trim/Mirrors
RST Dana
OH
One of the best mods you can do is replacing the tiny stock mirrors with beefy escalade mirrors. They bolt right up, come in black, and easily double your view. Ebay has new ones for about $150 each...
You have to make sure the options are correct, such as, heat, puddle, blind spot, turn and auto dim.
Pericles
I’ve done a search but can’t find the chrome delete thread with parts. Only seeing the picture thread. Can anyone help?
CMoore711
Post #41 has the part numbers listed: https://www.tahoeyukonforum.com/threads/rst-black-trim.101388/page-5
I do know of at least (1) that has been discontinued for the LWB models (Suburban, Yukon XL, Escalade ESV) and I believe it is GM OEM Part #84126996.
If you go the route of replacing the window trim you will also need to replace the gloss black front and rear door appliques as you will have to remove them to replace the window trim and it's pretty much impossibly to remove them without damaging them.
These are the GM OEM Part #'s for the K2XX LWB Models; Suburban, Yukon XL, Escalade ESV
Left Front Door Applique
84263144​
Right Front Door Applique
84263145​
Rear Driver Side Door Front Applique
84263146​
Rear Passenger Side Door Front Applique
84263147​
Rear Driver Side Door Rear Applique
84263150​
Rear Passenger Side Door Rear Applique
84263151​
Waiting_to_Dye
