Blazed's 2011 Tahoe Build
Status
Not open for further replies.
Goodinblack
I Like Tacos
Dirty South
Like 08 said check the rack too..... just in case. I take it the tie rods and the rest of the ball joints etc are all good because you just went through it all.
---------- Post added at 09:48 AM ---------- Previous post was at 08:19 AM ----------
Quite honestly though I do feel bad for you......... all the mods you do....... you redo....... such a freaking waste of time effort and $$$.
08grey
Mine was leaking internally. They actually poke a hole in the boot to see if its holding fluid. There were no leaks visible on the parking spot floor. I got lucky and found it before warranty expired. Check your dipstick first. It's a closed system so of its low there that's a indicator. Good luck.
Blazed
Blazed
Accepting Donations
The rack is a steering component right?
But isn't part of the steering column? Because I just had the column replaced because they said something would eventually go wrong with it and that was under warranty.
Also where is the dipstick for that located?
---------- Post added at 10:06 AM ---------- Previous post was at 10:06 AM ----------
[/COLOR]Quite honestly though I do feel bad for you......... all the mods you do....... you redo....... such a freaking waste of time effort and $$$.
Thank you....I know it really does suck..
08grey
No the column is separate. That is so weird why they would say it would eventually go bad. Steering columns are not a common fix.
The dip stick is in the pump cap. Right under the alternator.
Blazed
Blazed
Accepting Donations
I had them looking for a clunk noise which I eventually found on my own and they said while looking they noticed an issue in the column and that it will eventually need to be replaced but not now and I asked them to replace it then before I forgot and didn't have warranty.
But ok I will go check that.
---------- Post added at 10:14 AM ---------- Previous post was at 10:12 AM ----------
It appears to be quite low!
---------- Post added at 10:17 AM ---------- Previous post was at 10:14 AM ----------
Sadly the dipstick told other wise it's still holding I guess the liquid is just clear and looked low. Maybe it's just straight black idk but it's up to the cold full position.
08grey
Mine was a quarter inch off. Not much but I always check hot on level ground.
Blazed
Blazed
Accepting Donations
I'm headed to the dealer now... So we will see what happens.
08grey
I have read that the idler and pitman arms will make the front sloppy when bad. Of all the suspension parts I have changed in my life I have never changed those but when I looked them up they were these two small parts.
---------- Post added at 12:51 PM ---------- Previous post was at 12:51 PM ----------
Good luck.
Status
Madisonls98
