Blazed's 2011 Tahoe Build
Status
Not open for further replies.
Goodinblack
I Like Tacos
Dirty South
I think you could go without welding if you use the locking washers AND Red Thread locker.
Blazed
Blazed
Accepting Donations
Just changing out some cheap temp HIDs and realized they damaged my headlight housing....
It's one thing after another it's a good thing new painted housings are on the list.
Goodinblack
I Like Tacos
Dirty South
You would need new brackets though right.
I hope Tony is following this thread, as he sells a lot of DJM as well.
Modded
That Guy
Modded said they are basically one and the same.
I read elsewhere they are just valved differently.
I was just thinking 5100's this time because I have the HD's on my Excursion and I was not too happy with them.
The Tahoe / Suburban are much lighter trucks than my old tank so I wouldn't have a issues with HD's.
Woah. I forgot what I said, but I meant the Bilstein 4600s and HDs are one in the same. The 5100s are in a different league.
Blazed
Blazed
Accepting Donations
Modded can you explain the difference please?!
---------- Post added at 10:16 PM ---------- Previous post was at 10:00 PM ----------
I feel bad for you having to go through this NightMare Josh.
Haha well thanks for your sympathy
Well if DJM is this bad it needs to be known and it isn't his fault it's bad and it's a popular brand so it makes sense to sell it.
And no the brackets are fine just need a new way to hold them down.
---------- Post added at 10:17 PM ---------- Previous post was at 10:16 PM ----------
Jk just don't want to have to go through this and want something simple like a kit
I feel like this might out better than any kit.
---------- Post added at 10:29 PM ---------- Previous post was at 10:17 PM ----------
The only good that came from the shock extenders being shit is I found out that the belltech coils are not the issue.
---------- Post added at 10:30 PM ---------- Previous post was at 10:29 PM ----------
Still gonna get pedders tho
Modded
That Guy
The Bilstein HDs are Bilstein 4600s. They have stiffer valving than stock, but softer valving than the 5100s.
The 5100s are stiffer to keep the tires on the ground.
Blazed
Blazed
Accepting Donations
I wonder if I'd prefer the 5100....
Which would you say is closer to autoride?
Status
BetMic2025
