Blocking off front cv axles
Negligence
Wisconsin
I need to pull out the front cv axles on my 09 4x4 Tahoe. I'll never use the 4x4 again and want to know if I can pull the CV axles out, and just make a block off plate to the transfer case? I dont know if I'll need to switch to 2wd spindles or if the bearings for the 4wd are held together otherwise. So before people go saying trade it in for a 2wd blah blah blah, thats not an option, I just need the front cv's gone so any help is appreciated.:Handshake:
N
Negligence
Wisconsin
Got the info and task completed after a little bit of google work...it was easier than I thought, had it done in less than hour, thread can be deleted
Badluck
SE WI
Post the link to the info you found. I'll be doing this this summer.
N
Negligence
Wisconsin
I'll get some pics up tomorrow as well, I'll be at the shop finishing up the front bag mounts. Going to go and do it all the right way and instead of taking the CV axles apart to hold the bearings in I'm just going to order 2wd wheel hubs to bolt up.
---------- Post added at 02:40 AM ---------- Previous post was at 02:38 AM ----------
I see your from Wisconsin too, what part? I'm in the middle of Dodge Co.
Well Worn Chevy
