Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
If i did away with the motos what offset would work with that tire size and body lift? but in all honesty the more i think about it i just need to save up and get the rough country 4 inch suspension
I dont think it will fit. I have a 6 in susp lift and i had to trim "a bit" in order to clear the 35s. With just a body lift...ur gonna need to trim alot.
Was just looking at a two door last week with a 3" body lift on 35s. No specs on the wheels, but it looked ok. The truck was not up to par but the look was good
i had 35s with body lift and crank and block... since my trans went out removed it and have 16s with crappy tires and collecting parts to put the 10 bolt up front. massive crank killed my front end again
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
