Body Lift Pending Need Help
Gzes
the drifting 2dr
Wichita tx
I have a heat gun but it wouldnt have worked for me if i had used it. You gotta see in person how difficult it is to get anything in there period and a heat guj wouldnt have worked too big..but the only way is a welder and a bolt
mudslinger96
mudslinger96
Texas
My two rear bolts are exactly like those you posted maybe a bit worse I will soak them with pb then try the welding think to see if it works. Thanks for the input guys
Gzes
the drifting 2dr
Wichita tx
No problem bro. What part of tx you in? If close enoguh might be able to go and help ya out
HOEIN
Rhode Island
Working on a body lift for my 96 Yukon 4Dr but the rear bolts snapped off now need help removing them any input on how to get them out or is there another way of doing this
Get all the bolts loose/off on one side and jack her up, then get a good pipe wrench between the body and the frame and crank on the shank/threaded area of the bolt to back them out of the body, thats how I did mine anyways, 3 of them broke total but all were able to come out using this method. No welder needed just patience.
Ken
Thumper68
