Thinking it mybe a coil as well... pulled plugs, looked normal. If anything 4,6, and 8 had a little less soot around the edges.
bottom right is cylinder 1, top left cyl 8.
Plug wires ohm'd out at .385-.410, -EXCEPT!- one wire at .765. I had 3 left over OEM wires which all came in at .9something.
There has been ripples in my voltage levels in the datalogs.. swapped the wire, still stumbles/bogs.
Planning to pull the coils next. If I can't find anything there, I'll look into the knock sensor.
No burst knock, so either an ignition miss sets of the knock sensors, or something else is. (or something wrong with the wiring/sensors)
