~ Booster, master, or? ~
SunlitComet
OBS Jedi-Do Good
unknown at this time.
hydro booster would make a difference on pedal travel more because the hydro has a longer shaft for pressing against the mc piston. also get quicker pedal movement for less delay in panic braking.
nimrod.sixty9
nimrod.sixty9
Hold on, I got this.
Okeechobee, FL
I know it will help/change the braking, however, there is no way this truck was like this stock. I would be happy with stock actually; but I know it isnt there.
Wondering what else is there...
SunlitComet
OBS Jedi-Do Good
if the engine was off when you did i would just say you exhausted the vacuum reserve still in the booster. is it still firm when the engine is running or did the firmly drop dramatically?
perhaps a feel a :doh2: coming here soon in your next response, no?
nimrod.sixty9
nimrod.sixty9
Okeechobee, FL
No, this is while driving. I still need to test pumping with engine off to verify firmness then drop. That is how I do that right?
mastersorbet
