HOEIN
Can anyone do me a favor and test this.
See if the res squirts up fluid, with lid off, and when pressing pedal down?
Obviously have a rag covering just incase its the norm.
TIA
This is normal
TIA
you can adjust manually but it is cumbersome with out the drum/ shoe measuring tool to make it go faster. and if to much gap is there then it will have extra pedal travel. the auto adjusters will get stuck tho.
that is a ten inch drum set. judging by the parts breakdown by gm that adjuster is automatic but only applies to the parking brake effectiveness. it has no bearing on service brakes. the 10 inch does not seem to adjust for service brake wear. if worn down replace them otherwise longer pedal travel or softness so to speak. the 11 inch drums adjust for service wear and, by design, parking brake as well.
Sounds to me like the master has a bad seal and is leaking into the booster diaphragm.
I've seen this multiple times in the past and usually by the time you figure it out the brake fluid contaminates the rubber in the booster and you end up having to replace both.
