Bose amp???
Vdubbin
How do u test a factory Bose amp to see if it still works....I have it removed from the vehicle...radio worked but didn't get any sound from speakers so I pulled the amp and now I need to get it tested somehow
scoobyxj
If it's the regular Bose (not the LUX) then yes easy to test. The non LUX is whats called a dumb amp. It's basically a 5 channel amp with speaker level inputs.
The amp inputs/HU outputs should be as follows:
AUD Wire Color Amp connector Pinouts
RR - BLK B3
RR + DK BLU B4
LR - DK GRN/WHT B5
LR + BRN B6
RF - ORG/BLK B7
RF + LT GRN B8
LF - DK GRN B9
LF + TAN B10
MISS:
MUTE GRY/BLK B1
RSA ENABLE PPL B2
RAD ON SIG PNK B11
DRAIN WIRE BARE B12
The non LUX systems HU output a speaker level output so it would be easy to check to see if your are getting an audio output off it by using an old speaker. The amp can be tested by using a modified head phones jack and any MP3 or device that allows you to listen to it with head phones...
V
Vdubbin
Thanks for the info....how can u tell if it's a dumb amp or a lux amp tho???
RynoHarris
Texas
I can't really help you with testing it, except if you live somewhere relatively close to me I could loan you the one I took out of my console to see if it fixes your problem.
Sent from my HTC One X
WildHusker
