Bose Sub vs JL Audio
ChrisAU
Birmingham, AL
I think that sub would be a significant enhancement over the Bose sub, but it will want more power.
09tahoehybrid
09tahoehybrid
Ohio
So I will need a line out converter to use the stock nav headunit that will run an aftermarket amp that will power the sub...right? Do I need anything else?
Do you guys have any recommendations on what amp I should use? How many watts are needed considering the sub is a small 6.5?
Also is the PAC line out converter o.k or should I look at Schoche or Audiocontrol LC2i
Thanks
felixgun
Lafayette, LA
Look up the JL 250/1 or 500/1 for an amp. Have you thought about replacing the head unit? When I added the pioneer avic-z110bt to my tahoe it made the factory sub sound a LOT better.
shundal
NorCal
with just running a single 6 inch, you don't really need to add the LC2i. Stick with either the PAC or a cheaper Schoche LOC. Look for an amp that can push around 150 to 250 rms, and you can always turn the gain down if its too much. It would be best if you get an amp with a remote bass knob, so you can adjust the bass on the sub without having to mess with the bass settings on the stock head unit. This will help your stock speakers from having to take as big a beating, and sound cleaner.
This Alpine is a damn good amp for the money. A little more power than you will need, but you can turn the gain down, it will allow you to upgrade in the future if you need, and will give you the bass adjustability. http://www.woofersetc.com/p-6249-mrp-m500-alpine-mono-500w-subwoofer-amplifier.aspx
09tahoehybrid
09tahoehybrid
Ohio
Thanks for the reply's guys.
The only reason im keeping the stock head unit is because it displays the hybrid powertrain info on there, were it not for that, I would swap it in a heartbeat.
Also im pretty sure the JL Audio 6.5 is too deep at 4-3/16" to fit in the stock "box".
So I think my options are...
1) Kicker 6.5" CompVT
http://www.amazon.com/Kicker-6-5-CompVT-Subwoofer-10CVT652/dp/B0036MQWR4/ref=pd_sim_e_1
2) CDT M6+
http://www.ebay.com/itm/M6-i-SINGLE-CDT-AUDIO-6-5-MID-WOOFER-SUBWOOFER-CAR-SPEAKER-HD-M6-MIDBASS-6W0-/110767732105?pt=Car_Speakers&vxp=mtr&hash=item19ca457589
3) Hybrid Audio Imagine I6SW 6.5
http://store.12velectronics.com/products/-Imagine-I6SW-6.5%22-Subwoofer.html
What do you guys think, anyone have any experience with these or suggest something different?
shundal
NorCal
I had a jl stealthbix that replaced the console sub. It was a 10 inch w1. If that could fit, the shallow mount alpine 10 inch type r should fit. Would get lower and louder than a 6.5 woofer
2) CDT M6+
09tahoehybrid
09tahoehybrid
Ohio
I like the idea of the stealthbox, but its $500-$600 which is a little too much for me.
09tahoehybrid
09tahoehybrid
Ohio
Alright...I decided to try something a little different.
Since I want to keep the stock enclosure, I decided to go with a 6.5" Exodus Anarchy midwoofer as my "sub". It runs at 125w max rms at 4ohms and is supposed to be pretty good. Powering it will be a Rockford Fosgate Punch 300w monoblock amp, combined with a little polyfill in the enclosure and we'll see how it turns out!
I realize this setup won't bang like a 10" or 12", but I hope to get clean, clear bass that hits harder than stock. The cost for the line out converter, woofer, and amp came to $205 total.
wheatswake
houston texas
from what i understand the bose system/amp does not allow simple speaker swap. i could be wrong but i understood that the bose amp and speakers use some kind of clipping system where the ohms constantly vary, the amp is reading speaker load and limiting power output to sub/speakers in order to protect them. thats why the system does not get super loud. i went with the MTX thunderform 10 in w/ bulit in amp. even though i love jl, i think they over price the stealth boxes. mtx thunderform is much cheaper than jl audio stealthbox. ebay $300-550 vs. $500-600 . also mtx thunderforms come in four different setups, jl only has one setup. mtx- 1. just the empty box (put ur own shallow mount sub in it) , 2. box w/ base model 10in sub, 3. box w/ upgraded 10in sub, 4. box w/ base 10in. sub and bulit in amp. i got the last one w the amp and it rocks, plus no worries of having to mount another amp and run wires. plus if i ever blow this mtx 10 a replacement is $50 or i can upgrade to better sub.
09tahoehybrid
09tahoehybrid
Ohio
Thanks for the reply!
Im pretty sure the sub swap is possible using a line out converter (such as the one made by PAC etc.) I looked at the thunderform & stealthbox but found them a little pricey. I cant change stock nav head unit because it displays the hybrid powertrain info on my truck, so you can understand why I dont want to sink too much into this. I think the setup above will sound nice, it wont flex body panels...but that's not what I wanted anyway. Clear, strong, bass at bearable sound volume levels is what im after.
