Brake line failure. Common?
Doug118
I just picked up a 02 Tahoe last night which needed a power steering pump. Got that changed out today and on my test drive, the rear left brake line broke somewhere above the gas tank. Is this a common issue with these trucks? Instead of dropping the tank, I'm just going to run an entirely new line from master to caliper, on the outside of the frame rail. Should I be concerned with the other lines going bad?
Donnie Yukonie
Yates Caretaker
The only Time Ive hear of these issues with that year model is High salt winter road areas . I.E up north. If you have no rust Just do a good once over of the brake system and flush it accordingly
Doug118
Doug118
I live in New England and the only rust I have on the truck is the brake lines and very light surface rust on the frame rails behind the rear wheels. I'm really aggravated that it had to break right above the gas tank.
Donnie Yukonie
Yates Caretaker
How badly are the lines rusted? Just a surface rust or is there pitting involved?
Wake
Stafford, VA
I just went through this on my 98 Oldsmobile, brake lines severely coated with rust and one let go, luckily in my driveway instead of the freeway where I drove it the last time.
Age doesn't seem to always be an indicator either, on the Cadillac forums a guy is dealing with GM on a claim for a brake line that let go on his 2008 STS.
After doing a lot of web reading I chose a new brake line that doesn't rust. It goes by the name NiCopp, a nickel copper blend if I remember correctly. It bends very easily without kinking and I was able to use the factory routing over the rear suspension on my Olds. This nickel copper blend is supposedly standard on European cars for over a decade and hasn't had any issues that I could find. The only catch is that it costs about 2.5 times as much as steel line, about $50 for a 25' coil versus $22 for the regular steel lines. I found Advance Auto carries NiCopp.
The only other item to note if you haven't fixed this yet is that you will likely need a bubble (ISO) flare tool to make the correct ends. My 98 uses the bubble flares and I believe the GM trucks do as well. I had to order the tool on-line as nobody stocks anything locally other than the old single/double flare tool.
I plan to get under the Escalade and my other cars to inspect the lines and if I find them rusted I'll be replacing them this spring with the NiCopp stuff.
It's pretty sad that vehicle manufacturers aren't using something more durable on such a huge safety item.
Attached is a pic of the brake line I just replaced, right in the middle is a small dot, that's where she let loose. You can see how badly the line looks though, it's that way all the way from the rear to the front. This spring I'll also be looking into replacing the fuel lines as well as they look just about as bad as the brake lines.
Doug118
Doug118
Does anyone know where I can find a brake line diagram?
Wake
Stafford, VA
Look up GMPARTSDIRECT.
I found the diagram for my 98 Olds by looking up one of the brake system parts. The website showed a diagram of the brake system with part item number next to them. That should give you an idea of how they are routed.
Doug118
Doug118
Unfortunately GM doesn't sell replacement brake lines. At least none of the GM parts websites do
Duramax05blk
NH
Just had same line let go one the wife's denali yest. I am also in me England and have had many NBS gm vehicles and this is the first one to let go. A little research showed it to be fairly common issue though.
Sent from my iPhone using Tapatalk. Excuse my grammar the iPhone makes me iStupid!
Jellis02
